Thinning CA
Nitromethane is part of the mix of chemicals in the glue, so it should thin it. Not sure of the strength afterward, but it would work. Course mixing a bottle of debonding agent might work also. The reason alcohol kicks it off is that alcohol has some water in it. And the alcohol helps to mix the water into the glue.
