RE: Scale TG-3A Short Kit
The ulitmate scale towplane, our quarter scale Piper Pawnee is being cut as I am writing. Its off to the beta builder Saturday and he has a HUGE bag of goodies coming his way from SIG. This is the lineup of parts as it now sits for this first ever laser cut large-scale Piper Pawnee. You guys thought you had a grab bag full of cool stuff, check this out.....
Piper PA-25 2.7m Span
Span: 108"
Length: 72"
Area: 1700 in.2
AUW: 18-22 lbs
Power: 42-62cc
Functions: Rudder, Elevator, Aileron, Flaps, Throttle, Dusting Hopper or Tow Release, Choke (optional)
KIT BILL OF MATERIALS:
LASER CUT PARTS
PA-25 2.7M_01 18_4X32 - right wing ribs sheet 1
PA-25 2.7M_02 18_6X32 - right wing ribs sheet 2
PA-25 2.7M_03 18_6X32 - right wing ribs sheet 3
PA-25 2.7M_04 18_4X32 - left wing ribs sheet 1
PA-25 2.7M_05 18_6X32 - left wing ribs sheet 2
PA-25 2.7M_06 18_6X32 - left wing ribs sheet 3
PA-25 2.7M_07 316_6X18 - Turtle deck stringer notched formers fore and aft
PA-25 2.7M_08 18_4X18 - Instrument panel bulkhead and cockpit rear decks and rudder horn mount
PA-25 2.7M_09 18 PLY_12X12 - Firewall doubler and strut mount plywood rib and tail wheel mounting plate
PA-25 2.7M_10 14 PLY_12X24 - Firewall and all wing and tail shaped tips and edges
PA-25 2.7M_11 332 PLY_4X12 - Wing root ribs
PA-25 2.7M_12 18 PLY_12X30 - Fuselage right side plywood doublers and triplers
PA-25 2.7M_13 14 PLY_12X30 - Fuselage left side plywood doublers and triplers
PA-25 2.7M_14 116 PLY_12X18 - Fuselage lower hatch cover plates and doubler frames
PA-25 2.7M_15 14 PLY_12X24 - F2 and tank compartment floor
BALSA
3 QTY. SIGB067 1/4" x 1/4" x 48" Stringers
6 QTY. SIGB062 1/8" x 1/4" x 48" Stringers
7 QTY. SIGB071 3/8" x 3/8" x 48" Longerons
4 QTY. SIGB041 3/8" x 3/8" x 36" Longerons
1 QTY. SIGB019 1/8" x 1/4" x 36" Vertical fin
1 QTY. SIGB034 1/4" x 3/4" x 36" Vertical fin
1 QTY. SIGB496 3/16" x 3" x 36" Hard Balsa
1 QTY. SIGB307 1/2" x 3" x 12" Balsa Block
4 QTY. SIGB272 1/2" x 3" x 6" Balsa Block
2 QTY. SIGB308 1-1/2" x 3" x 12" Balsa Block
11 QTY. SIGB160 1/8" x 6" x 36" Balsa Sheet
SPRUCE
1 QTY. SIGGYS011 1/8" x 3/8" x 36"
2 QTY. SIGGYS035 1/8" x 1/8" X 48"
1 QTY. SIGBD005 1/4" DIA. X 12" Hardwood dowel
1 QTY. SIGBD002 1/8" DIA. X 12" Hardwood dowel
1 QTY. SIGGYS018 1/4" x 1/4" x 36"
HARDWARE
1- SUL395- Sullivan tank 32 oz.
3- RO308- Robart Pin Hinges
3- ROB331- Robart Ball Link Control Horns
1- 1/4 Scale Klett Tailwheel
1- DUB518 - 4-40 Pull/Pull Rudder Kit
2- DUB450TL - 4.5" Main Wheels
1- 3" White Spinner
1- DUB141 - 3/16 Wheel Collars
8- SIGPMPB280 - 080 Brass Screws
1- SIGBS018 - Brass sheet
3- KS103 - 5/32x12 Aluminum Tubing
1- KS256 - .032x4x12 Aluminum Sheet
4- KS255 - .016 Aluminum Main Gear
1- SIGGB006 - 1/16x2x12 Tempered Aluminum
1- DUB179 - 6/32 Cap Screws
3- DUB379 - 4-40 Control Rod for all surfaces
3- DUB902 - 4-40 Ball Links servo connections
1- DUB511 - Antenna Tube
1- SUL503 - Golden Rod for Throttle linkage
2- SULS547 - Flying Wire Brackets for tail.
2- SIGSH108 - 4-40 Flying Wire Brackets
1- SIGSH554 - Elevator Control horn
2- TMRC PA-25CP - .030x12x18 Plastic Sheets for Canopy
1- TMRC PA-25MG - 3/16 Landing Gear wire (3)
1 pkg. flying wires and crimps
1 fiberglass engine cowl PA-25 125
2 front strut fairings, left and right
2 rear strut fairings, left and right
.040 plastic canopy material
2 sheets plans, rolled
Optional scale instrument panel laser cut kit and plans
Optional scale functional dusting hopper laser cut kit and plans
Optional full flight pack with all digital servos
Optional BME power package
