RE: Seawind conversion
Greg,
It appears that prop clearance is going to be around 13" dia. It looks like most outrunners will be hard to use. A 3 or 4 blade Vario prop might work. The is one plane that may have to use a inrunner with a low ratio gearbox and higher rpm to get the required thrust.
Wendell
