RE: Dominator 200 Build
Setting the correct angle on a V-tail is super important, and not as easy as it seems when you cut in rearward sweep. Unfortunately, my lovely assistant, Erica, was not here to help me, but I managed to build a temporary jig which I T-pined in place to set and hold the proper angle until the epoxy dried. It worked flawlessly and the angle when finished was exactly 113 degrees with no twist.
