RE: Beginner Modeler
Hi Joshua11,
Piper Chuck is right on the money. Ignore his advice at your own pearl. If you try to build and fly this plane you will distroy it. Then how much money are you going to have to spend to learn to fly. It's very likely that you will not only distroy the " T-BOLT" but the engine and some of the radio gear. Then how much are you going to have to spend to get into the hobby. The P-47 doesn't even make a good second plane. It's a plane for EXPERIENCED pilot's only. By that I mean someone with 50 - 100 flights on several different types of planes. As Chuck noted sory if this sounds harsh, we just don't want to see you loose the plane and your passion for the hobby with a bad and expensine first experience.
Just my 2 cents.
Good luck
Darren
