RCU Forums - View Single Post - which engine should I use?
Old 10-29-2002 | 03:04 PM
bobi
Default which engine should I use?
The zdz 40 will be too much an engine.
The balance 3 engines will do the job of developing enough power. I would pick either the Mvvs 1.60 or the RCS 1.80. Check the ground clearance as you would need 18-19 inch props for these engines.
