RE: U-Can-Do 3d 46?
Barry
You were dead on concerning weak set-up on tail-wheel. Bumped it and knocked rudder loose. Will put the
tail-wheel bracket on fuselage instead of supported on rudder. Flew 2 flights yesterday in 10+ mph winds.
Sweeeeeeet! Definately flies slow enough on low rates to be a good trainer, if you have a little help with landings. So far Saito 80 is plenty of engine for me. Watched what happens when you fly a UCD low with a strong tail wind. Flipped it over and right into the ground. Busted fuselage in half. so stay high.
Doug
