RE: E-FLIGHT BLADE CP
The paddles are not quite perfectly aligned. After a dump a couple of days ago there's a very slight bend to one end of the flybar. As for the paddles themselves, it seems they should be level with the rotor hub, is that right?
I've held off replacing the flybar because I haven't looked into how the paddles should be oriented when reinstalled(level with each other, or pitched slightly to give a bit of lift).
