RCU Forums - View Single Post - FADEC Hall sensor troubles...
Old 09-24-2005 | 03:52 AM
Gaspar's Avatar
Gaspar
Default RE: FADEC Hall sensor troubles...
Surely the problem is the magnet, Neodinium magnets loose the magnetic properties if heated, so, if you had enogh temperature to burn the cables, sure that the magnet is de-magnetized. Standard Neodinium allow up to 80ºC, but the one you have (if a wren nut) is OK up to 150ºC.
Gaspar
