ORIGINAL: slo v rule
Thanks, i opened up the servo and the gears had just got displaved chers
Gears don't get displaced. If this is the stock servo, or for that matter, any servo, you need to look at every gear on it under a magnifing glass. If you heard a snap, sonething broke. The gears are mounted on shafts, they can't move, other then rotating.
If they are the stock servos, you can buy rebuild kits from Horizon, for the gears.
