RCU Forums - View Single Post - Spark Plugs
Thread: Spark Plugs
Old 09-24-2005 | 10:48 AM
Flypaper 2
Default RE: Spark Plugs
The way the heat range is mechanically determined is the distance the heat has to travel from the end of the centre electrode to the head. If you take a cold plug and a hot plug side by side you'll see a very short ceramic on a cold plug and vice versa on a hot. A loose plug can lead to engine damage, as it loses it's heat transfer to the head and acts like a very hot plug which leads to detonation. Hope this helps.
