RE: Another Beginner Build - Sig Somethin' Extra
The SSE fuse is one of the easiest I've ever covered. Just five pieces--bottom, two sides, and two turtle deck halves. The only compound curves were in the turtle deck, hence the two separate pieces for that. The cowl deck was covered with the same pieces I used on the sides, just up and over, with a seam down the middle. I was planning to use a separate piece for this, but didn't need to.
It's fine to cover in sections, though. Just get it done.
