ORIGINAL: walkerNCST
[link=http://www.rpmrcproducts.com/products/wheels/truck/index.htm]RPM Wheels[/link] Get the wheels designed to fit the Losi trucks. Make sure you get a set of fronts and rear wheels. These wheels will fit without any modifications. Then glue on any set of tires designed for 2.2 wheels and you will be good to go. The starz wheels are the ones I have on my evader.
with the losi truck wheels will the back slot stragit on the spring pin and will the front stot on to the axel
thanks heps
