I wish I would of came back and read the thread 6 hours ago before I covered the rudder.[
] Won't fret though. I can always slice a small hole thru the covering and insert a dowl to add flying wires. Thanks for the warning though. Keep the suggestions coming. I've learned alot already! My new rule is to
1. Read the thread replys
2. Start building.
Have a quick question though. Anyone ever use the Sig Aerokote covering before? I've been using strictly monokote for years. This stuff was $5 cheaper at my LHS. Now I see why it was so cheap, the adheasive glue melts at such a low temp (220 Degrees). I don't know if its the melting temp of the glue quality, but if you're not careful it gets all over the surface you're covering. Anyone have a "fool proof" way of using this stuff?
