RE: E-FLIGHT BLADE CP
blade cp upgrade works really well
remove the two orings and replace them with two 180 gearbox bearings (perfect fit ). then remove the two inner washers and reasemble i did it to mine and well it gets a little bit better response and lift is more responsive if you do not remove two wahsers one side or the other will bind
