ORIGINAL: Blue_Moon_
foxy42, yeah, sorry!
"To put one of the top engines in a Inferno sports (if it's stock) must be equal to put a Ferrari engine in a Fiat. "
Do i need to replace anyting else in the inferno before i change the engine?
Its quite stock except for the hardened steel gearwheel.
Personally, if your going for "THE MOST POWERFUL ENGINE" then you'll need a chassis that can take the power. The stock MP7.5 WILL shear the drive shafts, strip the diff internal gears, suffer from lack of braking, snap shocks, lose arms and generally just fall to pieces. Better to get a top end chassis to match your intended engine. If you can find a Black Magic, that's what I'd go for. But the V-Specs are reliable and powerful, I've seen 2.94 Bhp and a top end of 44,100 rpm quoted on dyno tests. Certainly not to be sniffed at.
Adam, just because I like something does not mean you have to be unimpressed by it.
