RE: igntion module??
CH ignition is not a direct replacement for the older 3W ignition or any DA ignition. The old 3W and DA use a pickup coil to sense the timing of the magnet in the hub. The CH and new 3W use a Hall sensor. Not sure if the magnet polarity is correct for a CH to 3W interchange. You will also have to retime the ignition by putting the sensor in a different location.
