RE: learn from this
Hi,
In regards to the third item, wouldn't a prop installed backwards produce backwards thrust (if the engine was running in the proper direction)and push the plane backwards? How could the plane get off the ground with a reversed prop unless it can fly backwards? :-)
Tom
