Moki 2.10
Has any one tried a larger diameter prop? I'm using a Mejzlik 20 x 10 on my Moki and it turns about 7500 at sea level with no nitro. The plane flies okay, but I want more thrust and down-line braking. With the 20 x 10 I have way more speed than I need and the throttle response isn't great. I believe the Moki 2.10 reaches peak torque at about 7500 rpm. That's where I want to be at full throttle on the ground. If you've used a larger diameter prop, could you tell us what it was and how it worked (full throt. rpm on the ground)? Thanks.
Woody in Maryland
P.S. I'm now running a Perry Pump. It seems to help with consistent mixture no matter the plane's attitude.
