RE: Showtime
I use the karbonite long arms(double arms)that come with the digitals and I think with the HS625/645.If I just need one arm, I dremel off one and trim it,if using 4/40 screws&ball links, you need to drill the holes out a little.They dont give you max throws but pretty close.
