RCU Forums - View Single Post - 421 b settings
Old 09-27-2005 | 04:42 PM
kx250ryder's Avatar
kx250ryder
Default RE: 421 b settings
Having the highest possible idle puts you closer to the power band when you go to accelerate. This means less time between when you hit the throttle and when the clutch engages. Since the engine is revving higher, it is less likely to stall as well, compared to an engine that is idled low enough to barely stay running. This does mean that you will burn through your available fuel faster when you are upside down though.
