RE: Engine pressure problem, help needed
Replaced the pressure tube and only been through 2 gallons only. Rebuild would be a petty after only two gallons. The weird thing is that the engine runs fine once it's started but when the tank is empty and I need to refill, I have to go through the same little circus again.
