ORIGINAL: john agnew
RCD
Don't forget Hitec digital servos. I have used them exclusively in my jets using Futaba equipment and have had zero problems.
They have an excellent range of servos and you can use 6 volts if you need extra output ( unlike JR) they are, of course, much cheaper than JR for an equivalent output.
John
I use 6 volts on all my aircraft, with JR digitals. Torque values are also provided by JR at 6V...What makes you think you cant use 6V? Futaba digitals (at least most of them) are only reated for 4.8V which is one of the main reasons I dont use them....
