RE: Turbo Regulator "DUAL SWITCH"
Hello,
You can do that. The TurboReg has Deans UltraPlug inputs so I imagine you would have to change your switches over to Deans on their outputs.
You should note that the TurboReg is not 100% redundant. It has two transistors in it that actually regulate the output voltage but they share a common control circuit.
Please let us know if we can be of any further help.
