RE: Sig Koverall-substitute?
You can use Super shrink coverite, which is basically the same polyester fabric material as Sig's Koverall and dress lining material, although the latter come in different weaves and some do not shrink well, it has to be used with dope though, Coverite does not, it already has glue on one side, goes on very easy, and then you can also order Solartex form Balsa USA, similar to Coverite and use either white or silver and painted on later, or just use the colored ones. You should be able to get dope from Sig, and also check aircraft supply houses and get Randolph dope, same as Sig's.
