Looks like they have an
87" Yak in the works also [sm=lol.gif]
http://www2.towerhobbies.com/cgi-bin...?&I=LNLDE1&P=G
REQUIRES: Engine: 3.0 - 4.8 cu in (50 - 80cc) gasoline
Muffler:
Radio: At least 4 Channel
Servos: 8-9 (2-aileron, 2-rudder, 2-elevator, 1-throttle
Servo Extensions:
Y-Harness:
Spinner: " ( mm)
Misc. Items: 1/2" foam rubber padding, fuel tubing,
fuel filter, propeller, building and field equipment.
SPECS: Wingspan: 87" (221cm)
Wing Area: 1468 sq in (94.83 sq dm)
Flying Weight: 16.5-17.5 lb (7484 - 7938g)
Wing Loading: . oz/sq ft ( . g/sq dm)
Length: 84" (213cm)
Airfoil: (Fully- Semi-Symmetrical or Flat Botm), mid-wing
Center of Gravity: - / " ( mm) Back from the wing's leading edge
Control Throws- High Rate Low Rate
Elevator: Up & Down / " ( mm) / " ( mm)
Rudder: Right to Left / " ( mm) / " ( mm)
Ailerons: Up & Down / " ( mm) - / " ( mm)
Now if it had a true 1468in of wing area and came in at 17 pounds with a EV58 on tuned canister it would rock.
