All of the above [sm=wink.gif]
Well the engine is to go into a 60 to 90 size scale plane for fun stunt flying and Unlimited vertical climbing if this is possible
yellow748
ORIGINAL: Wayne Miller
Hi,
I think one needs to define what is expected from the engine. Once that is defined, you can select "the best engine" for that application.
Do you want:
Most reliable?
Most power?
Highest RPM?
Easiest to maintain?
Best availability of parts (most common)?
Best cost for performance ratio?
Most Power to weight?
etc.
Once the above is defined, I think the answer will be more relevant to what you want. Can you tell us what you are looking for?
Fly4Fun,
Wayne
