RCU Forums - View Single Post - nitro evader problems need help please
Old 09-29-2005 | 12:45 PM
jnatale3's Avatar
jnatale3
Default RE: nitro evader problems need help please
When I had that problem with my evader bx, my pull start would pull very easily after dying out. It turns out my compression dropped too low when the engine heat expanded the sleeve, and then after 15 minutes it would start again once the compression came back up. Maybe you should try to see if you can turn the fly wheel with one finger easily. If you have little or no resistance, try a new piston and sleeve, otherwise, sounds like a plug.
