RCU Forums - View Single Post - New pattern stuff from Japan
Old 09-29-2005 | 02:29 PM
can773's Avatar
can773
Default RE: New pattern stuff from Japan
ORIGINAL: MHester
Somehow I'm reminded of the anhedral stabs that swept pattern about 25-30 years ago thanks to Hanno.....
Monkey see, monkey do. I wonder how many people putting these things on thier planes actually know what they are aupposed to do?
I'm sure there is a little something to it. The question is how much. But it's funny to watch
-Mike
I have an exact copy of CPLR's on my Enigma, there is something to it as it completely removed the pitch mixing I had in knife edge even with extreme amounts of rudder. It also significantly increased the effectivness of the rudder especially in level flight. I am down around 15 degrees of deflection for everything but snaps/spins, about 50% of that is required for sustained knife edge flight. I was running around 20 degrees for a similar feel prior to adding the wing.
So in my opinion it certainly has an effect.....the question I am still resolving is if the changes caused by the appendage is truly benefitial or not. The plane flew great before and it flies great now
