RE: Need help with radio glitch
Hey pg, I just checked your glitch vid. I believe you need to lean up your midrange. I had the same problem and finally got my engine tuned correctly for the most part. It seems when the head speed rpm's are too low the heli bounces around. Your engine should run rough for a minute while in a hover, then it should clean out and start screaming. Proper head speed means much better control, stability, and lift.
Oh yeah, I doubt your super 9 will work with the cp blade, I already tried, mine didn't.
