RCU Forums - View Single Post - Engine turned charcoal grey
Old 09-30-2005 | 10:28 PM
  #44
D Bronk's Avatar
D Bronk
Default RE: Engine turned charcoal grey
FLAT black will pull heat out of a casting,and release it about the fastest.of all colors.A very light coat, of zinc chromate(you should almost be able to see the aluminum through it) primer,also in a spray bomb..will hold the top coat ,really well..THEN just enough finish to cover the primer..This is one of those cases, where more, is NOT, better... D.B.
