RE: Problems breaking in engine
Check in the manual to find exactly where they are and set the needles to base setting. It's should to tell you exactly where everything is and what settings to have on break in. I would assume the low-speed needle is just below the arm that rotates/slides the carb and the idle is beside the air intake hole.
