RE: Help ! Break in Os 160 with perry pump
The best way is to start the motor without the pump in line and get a decent needle setting. Then put the pump in line and adjust the pump only to get it to run correctly again. My OS 160 / Perry pump set up worked flawlessly, but you will need to lean out the pump quite a bit or it will flood.
