ORIGINAL: RaceCity
What kind of problems are you having with the Quickee motor that makes you think the tank is too low?
Best solution is "raise the tank". These motors don't need pumps to run.
'Race
well, once i get full throttle to be set at max, just a clik rich, i cannot hold the nose up without it going lean and dying. its like it just aint getting enough fuel and i cannot get it to run in a nose up position at all. when i tilt nose down, it will richen up and run fine. i have tried both needle adjustments and cannot fix this problem. one thing i am wondering is if i have my pressure tap for exhaust/tank pressue right. do you think that a bigger fitting would help? also, i have the fitting mounted on the header at the engine and not on the pipe. would changing that help? any help is appreciated of course. thanks.
