RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 10-02-2005 | 06:48 AM
  #846
stevennh
Default RE: E-FLIGHT BLADE CP
cruzmissle,
Thanks, I would like to see the layout. I tried to put it together like the old one, just with the extra bearings, but I was using the existing hardware (for the 2BB) and the shaft that holds the holders seems a bit short and I ended up with too much play. I put two washers in but that seemed too tight. A picture would be great... I thought the new setup would include a bearing at the rotor shaft, but it sounds like the extra bearing in the holder is the only change. My Blade works well now anyway so I guess I should just leave it alone.
Steve
