RE: Excelleron 90 - metal hinges?
Touch your radio antenna to your motor or muffler while the plane is switched on. wive's tale?
Metal is heavy. Metal rusts. Metal won't give under pressure. (Say you over G on a downline and get some flutter. A nylon or CA hinge will give a bit and hopefully not rip out of the wood. If it's a large plane and you want more CS "control surface" support use some DuBro point hinges.
