So, I decided to do a little work on her today. I have glued all the control surface hinges, installed main and tail gear, installed the engine mounts, mounted the engine, removed the fuel tank and altered it so I can access it in the future, re-installed the fuel tank, and altered the nose cheeks to give better spacing around the high end needle.
The only thing I seem to be missing is the way you make the spinner attach to the engine shaft.... I seem to be missing a part that would let the spinner bolt attach. If anyone knows what that might be called, let me know so I don't sound like a dolt when I go to the LHS tomorrow to get one.
