RCU Forums - View Single Post - FZ110 fuel problems
Old 10-02-2005 | 09:30 PM
Rumple's Avatar
Rumple
Default RE: FZ110 fuel problems
ORIGINAL: marvintm
In the picture posted on the left, the reg is on backwards.
You know, I think you're right. I can swear I had 2 or 3 flights after re-installing the reg yesterday. Will the motor run with the reg installed backwards Dave?
As for which reg has the little nib, I can only speak of the 2 regs I have. The small off-center nib is on the older, large plunger reg, and the larger centered nib is on the newer, smalll plunger reg. I'm not sure if that is universally true, maybe Dave will chime in.
Kurt
EDIT: I added a pic with the older reg reversed compared to the pic in my previous post. Now the little off center nib faces the front of the motor.
