ORIGINAL: Advent
Just a heads up....
For anyone assembling this plane before you complete step #8 in
the manual you should check your incidence on the stabilizer half's.
Mine right stab was out 1 degree.
Once you drill the second hole in the stab tube you are locking the
left and right side together. If the incidence on the left and right side
are not equal you might not be able to make the adjustment later.
The fuselage holes that stabiliser halfs slide into are predrilled and laser cut from the factory. There must be some problem with your stabilisers, may be one of two is warped.
I haven't checked mine but will do. Don't expect this plane to have the accuracy in building such as planes by PL Prod and ZN Line, if you want to make it perfect straight you have to put some work on it. Personally I corrected some warp found on ailerons and one of the stabilisers.
