RCU Forums - View Single Post - 35% 3D models in the UK
Old 10-30-2002 | 10:59 PM
TD1
Default 1/4 scale Glens Sukoi
3d_cap232
I haven't had the change to weigh the model assembled on a decent scale, I had the fuse with all the electronics, engine, batteries, except for the main wing and undercarriage on a bathroom scale and was showing around 13.2 lbs so I am assuming the total weight to be around 16.5 lbs. I'm running the 3w 42 (single)with the exhaust from catus aviation for the 3w engines (i don't know what brand it is) and swinging a master airscrew 20x10 @ 6500 rpm. The engine is still fairly new and I want to try the Menz 20x10 but the local shops are out of stock so just have to wait. At the moment you can get much vertical out of the all set up, just i bit disappointed
