ORIGINAL: CGAV8R
The problem I ran into when I did the mix with another channel is only one elevator half would move when I used the trim.
Make sure both halves move when you trim it.
Aaron
You right. I used sub-trim function on my radio to set it up. i dont know if T6EXA have this function.
It's still not the perfect way to do it, but its much cheaper, and it works after a few fly tests.
