Metal to metal contact is the prime suspect and is the most likely cause. This is often very hard to track down. ( muffler rubbing maybe?) Antennae location and mounting is the second most likely cause. Servo problem is possible, but I think it is unlikely. You will find (hopefully) the problem in metal to metal and or ant. location.
Good luck.
