RCU Forums - View Single Post - Engine Mounting Problem-OS FS-70 II Surpass
Old 01-13-2002 | 11:06 AM
EXCAP232
My Feedback: (12)
Default Engine Instillation
Flyboy,
It is doubtful the 3/16 will make much difference to the flight envelope of the plane. What will make a difference is the weight of the engine as compared to what the plane was designed for. Check the balance carefully as the heavier engine may palce the center of gravity forward enough to make the elevator input "mushy" or require more elevator throw than called for in the plans. Good Luck! Bill
