Exponentials.....when and why?
the trim setting stays the same, the linear motion changes,the low and the high end of the control do not change,the center portion of the motion is affected. On high rate I have 85% on rudder on and elevator,that allows 3D at the upper end of the control and softens the movement around center to keep the plane controllable,my Edge has 45 degree travel in the tail, it would be hard at max throw to control the plane
