RE: 1/2A 150ish Build
Once the sides were dry, I pulled in the fuselage sheeting at the nose(carefully, so as not to crack the sides going around the bend), and Ca'ed it in place, making sure to keep the bottom edge seated on the fuselage bottom. Same process with the aft fuselage sheeting, with a pretty good amount of pressure on the sides behind the F2 former while th CA set.
