Exponentials.....when and why?
I did go to fly today, however, I didn't get a chance to try out EXPO. I forgot to look at the trims on the tx to make sure they were centered. Took off with full up elevator trim, on high rate, couldn't find trim with thumb, figured I would just come back around and land, cut throttle back to idle, had a bit of a tiff with a tree on the way back to the runway on final turn. Anyway, after I fix the lower left wing tip (not bad,could have been alot worse), I will give EXPO a try. I was hit by a sudden gust of stupidity.
