RE: AEROBIRD EXTREME MODS!
Yea I bought one of his tails for my challenger. He does a pretty good job on them. The only part I did not care for is he sends you rods that you tie the control line to. Then the rod slides thru the control horn. You bend the rod to adjust the trim.
I guess this would work, but I didnt use them. I used the stanard HZ part.
I also had a problem with the tail being to flat(not enough V) when I installed it. This was probally my fault. I just used fishing line to pull the tail closer together.
Now for the good part. I ran the control line the the second from the bottom hole on the horn. First flight was wild you can really make this plane turn. Straight up loops and dives straight down. This was in the standard mode. I have yet to put in pro mode. just kinda taking it easy with this one.
