RCU Forums - View Single Post - e-flite mini edge 540
Old 10-04-2005 | 08:54 AM
  #51
DrDeath
Default RE: e-flite mini edge 540
Hey Chevyman,
Why so tail heavy? Here is my setup
E-flite 400 4200 Stock gear box 10T gear
Castle Creations Phoenix-35 amp mounted on the left side of the plane
3 HS-55
1 E-flite S75 Servo Rudder Pull/Pull
2100 pro-lite TP battery, shoved all the way to the front of the motor mount
RS6UL Mounted to the right side of the plane
Balances right in the middle of the suggested CG. I have everything in the stock location. How much lead did you use?
DD
