ORIGINAL: raideron
Kaos.... On Mags and inverted engine positions..... Be careful.....
Mags are great engines..... upright..... And inverted if the tank is
close to the carb...... Or running a regulator........ But the inverted
Mag's I have seen, may start easy or OK... But gives low throttle
fits while flying if it's inverted and the tank position is not correct...
In regards to the U-Can-Do 3D .46, what would be the correct fuel tank position? The Magnum XL 70FS has a rear mounted carburetor, so I don't see how it could get much closer to the fuel tank.
Kaos
