RCU Forums - View Single Post - husqvarna 345 conversion
Old 10-04-2005 | 06:21 PM
tankie
Default RE: husqvarna 345 conversion
It's going into my Airtruck to replace the ryobi 31cc. The ryobi seems too small for this model now plus I need to add about 3lbs of lead to the front to balance it. So that weight may as well be in the form of a bigger/heavier engine with lees lead to add.
The engine is brand new. Someone purchased it and used it once then ran it over by accident with a ute crushing the pull start and few other things so it was an insurance write off. Local repair shop got it from the insurance company for the engine which is fine and not broken in yet. Got it for $250NZ.
the bottom half of the crankcase is plastic and needs to be cut from the body of the saw and the coil is mounted off to the side of the cylinder but a bracket can be made for it or fit a CH ign.
ID:	334046   Click image for larger version
ID:	334047   Click image for larger version
ID:	334048   Click image for larger version
